Changing from 11-25...
[Closed] Changing from 11-25 to 12-27 or 12-30
[#5388876]
As a recent convert to the darkside here's my newbie question.
I've entered a particularly hilly sportive and think I'd want/need a different block on the back.
My current steed sports 11-25 gearing and I am considering fitting either a 12-27 or 12-30.
I've always been a masher on an MTB but trying to learn to spin a higher cadence on the road.
I'm leaning more towards the 12-30 set up.
If I do fit such a large rear ring will I need to lengthen the chain to fit or would I get away with keeping it the same as for the 11-25?
Thanks in advance for any advice or opinion.
TMS
Posted : 03/08/2013 8:47 am
You'll definitely need to lengthen the chain for the 30.
Depending on the length of the mech it probably wont cope with such a wide spread.
Posted : 03/08/2013 8:54 am
.. I'd change to a compact on the front if you can.
Posted : 03/08/2013 8:55 am
You'll probably have to lengthen the chain even if you just go from a 25 to a 27, depends on how much slack there is currently. I did the Whitton a few years back as a very raw road bike rider with an 11-25 at the back and it was fine, if a little harsh on Hardknott - compact chain-set - this year I went with an 11-27 and it was, slightly, easier. I guess whether you go to a 30 depends on how strong a climber you are. I'd say I was pretty average, but my local riding in the Peak is hilly, so I guess I'm used to it,.
What I wouldn't do is fit a larger cog at the back and reason that you won't ever go 'big-big' then end up tearing your mech off in a moment of absent-mindedness.
You don't say btw, if you're using a compact or a standard double. If the latter, a mate of mine stuck an 11-32 XT cassette and a mtb rear mech on for the Whitton a few years back and it worked for him. Looked horrible though 🙂
Posted : 03/08/2013 9:06 am
 OCB
I've run an Ultegra mid-length-cage rear with 22-34-44f and 12-28r, but that's as far as I'd push that length of cage.
Both my road bikes have 11-32's on now, and both have long cage XT mechs as a consequence. Going to 27 might be doable on your existing chain, but going up to 30 [i]almost certainly[/i] 😉 won't be.
Posted : 03/08/2013 11:01 am
50/34 on the front and 11-28 on the rear for living in the lakes 🙂
Posted : 03/08/2013 11:58 am
11-34 on my road bike with XT long cage. 53-40-30 up front. Lovely having the range.
Posted : 03/08/2013 12:56 pm
what mech at the back?
road ones probably can't (officially) clear a 30t cog. 12-27 or 12-28 should be OK normally, depending on the difference up front.
Posted : 03/08/2013 1:05 pm
Put it this way, if your bike's set up right then if you add teeth, you should add links. But is it?
The other thing though is that it depends a bit on the operator- even if you run out of chain in the crossover gears, that only matters if you use them, so as long as you only use the lowest gears in a smaller chainring it ought to be OK. Personally, that doesn't work for me, sooner or later I'd shift down in the big ring into a bad gear.
Posted : 03/08/2013 1:40 pm
OCB - Member
similar here here glad to here not the only one except run a "touring mtb triple" 24 36 48 Long cage XT and 12-34 with 700c 32mm and 11-32 with 25mm tyres - it looks ugly but you can ride up anything and if you spin out it means you can relax and look for a beer stop
probably worth replacing the chain if you switch the block unless it is really new and funds are very tight
Posted : 03/08/2013 2:05 pm
I put a 12/30 cassette on my trek madone 6,9 for the Dragon ride as I felt that I could use some lower gears but I didn't want to change from my 53/39 chainset.
The cassette ran perfectly with a short cage Ultegra DI2 rear mech without lengthening the chain.
The cassette also runs perfectly on my Cannondale Super6 with a Dura ace short rear mech.
A friend tried one on his Specialized Tarmac SL4 with SRAM Red short mech and it wouldn't work.
Posted : 03/08/2013 2:48 pm
 tang
I think latest generation 105/ultegra short mechs are good for 30t and mid up to 32t.
Posted : 03/08/2013 4:09 pm
