Changing fox fork l...
[Closed] Changing fox fork lowers from q/r to 15mm??
[#4146671]
Ive currently got a set of fox float forks on the front of my bfe and am considering getting a set of the same forks but in 15mm q/r as a mate has offered me a deal on a set of dt swiss wheels with 15mm.
is it possible to swap the lowers out for a set of 15mm lowers??
if so where would i look for a set of lowers??
cheers
steve
Posted : 09/07/2012 7:54 pm
cost prohibitive from what i've seen.
Posted : 09/07/2012 7:57 pm
Ive found legs on a website for £150 and they would be serviced at the same time.
so you might be right!!
Posted : 09/07/2012 8:05 pm
that's cheap, seriously. forks are like £600 new?
Posted : 09/07/2012 8:06 pm
What about used though??
would it work out cheaper to buy a used set and then sell mine or just convert mine??
Posted : 09/07/2012 8:07 pm
Did it. Makes a bit of a noticeable difference...if you know what I mean.
can't remember but think lowers were £200 ish.......... bit steep for the result
Posted : 09/07/2012 10:07 pm
