chameleon ebb help
[Closed] chameleon ebb help
 rob2
[#1693822]
bought a chameleon off here - cheers guy.
What have I done wrong to the ebb?
Bottom bracket is at 12 o'clock so thought I'd rotate to 6.
Took the two small bolts out.
Took the big bolt out and Bugger me I can't get it back in...
Looks like the nut it screws into has dropped out of place.
How do I a. Get the bolt back in and b. Rotate the ebb?
Love the bike mind!
Posted : 10/06/2010 10:37 pm
Don't take the bolts out - only loosen them, then use a 5mm allen key in the holes to rotate the shell.
Posted : 10/06/2010 10:43 pm
 rob2
cheers. I've already taken the bolts out. Problem is I can't get the big one back in. Any ideas?
Posted : 10/06/2010 10:48 pm
HAHA! I did this. First see if the long bolt and cylinder shaped bolt will do up, if yes then slot the bolt back in its hole and push it down to the opening, you can use cotton buds to correct the position. Then it should tighten the first or second try.
If no then you have threaded the bolt like I did call Jungle and ask for a new one they sorted me for free.
In regards to the EBB lots of copperslip or grease then there are instructions [url= http://www.santacruzbikes.co.uk/tech/chameleon_tech.html ]here[/url]
Try here http://forums.mtbr.com/showthread.php?t=492389
Posted : 10/06/2010 10:52 pm
 rob2
tails, not wanting to sound like a total monger but do you just use the cotton buds to get the nut in place? Or can you take the thing apart?
Posted : 10/06/2010 10:56 pm
I never took the bolts out when I was adjusting the EBB so I'm not sure what you can do. But it seems that since you've taken out the bolts the wedge should come appart and allow you to remove the whole unit. Then re-align the wedge nut with the bolt and put the two parts, eccentric bb and wedge, back together. Then grease and replace in the frame.
have a look here: [url= http://www.santacruzbicycles.com/tech/chameleon_tech.php ]EBB help[/url]
Hope this helps a little and you get it back together.
Posted : 10/06/2010 11:05 pm
 rob2
trailseeker - cheers for the linky. Its all starting to come clear!
Posted : 10/06/2010 11:06 pm
 rob2
cheers guy/baronspusulike. Shall post pics when done.
Posted : 10/06/2010 11:08 pm
Just knock it out of the non drive side and reassemble it out of the bike. Give it a grease while your at it.
Posted : 10/06/2010 11:11 pm
Good to hear it's coming together Rob. Looking forward to seeing you nail Set2Rise on it next year 😉
Posted : 10/06/2010 11:29 pm
