Chainwheel challeng...
[Closed] Chainwheel challenge
[#5873593]
Any chainwheel experts on today? Am lost in the chainwheel maze for my ancient Kona, any advice on replacement options warmly welcomed!
The current one (original I think) is a M569 22-34-42 and it looks like this:
After fitting a few new grannies and medium rings, I've finally worn out the big ring and doesn't look like there's any replacements out there.
These chainwheels seem to be a desirable retro item these days but I'm not really bothered. Just want something that'll be as direct a replacement as possible and compatible with the 8 speed kit on it. Is still a great light xc bike (mini mula/rc-36) and happy with it as it is.
Here's hoping...
Posted : 20/01/2014 5:10 pm
This would probably do the job and cheaper than a new chain ring I suspect.
[url= http://www.chainreactioncycles.com/shimano-acera-m361-triple-chainset-square-taper/rp-prod106885 ]http://www.chainreactioncycles.com/shimano-acera-m361-triple-chainset-square-taper/rp-prod106885[/url]
Posted : 20/01/2014 5:17 pm
Nice one, that looks just the job. Any other suggestions very welcome - maybe something lighter I guess - but the 7/8 speed compatibility, same gearing and low price look pretty good to me.
Many thanks!
Posted : 20/01/2014 5:24 pm
If you wanted to keep it looking retro then it may be worth trawling ebay for some Race Face Turbines (look for the 4 arm ones to keep you going longer with replacement chainrings), or alternatively have a look at getting some Middleburn cranks which last for ages too but will be more in keeping.
Posted : 20/01/2014 6:13 pm
Thanks for that too, will have a think and do some trawling. Matt also kindly emailed me to say that M570 crankset will do the job and should be 8-speed compatible. They do look pretty similar to the old ones and also a good price.
[url= http://www.ebay.co.uk/itm/Shimano-FC-M570-Chainset-44x32x22T-175mm-/350973374927?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item51b7a4b1cf ]Ebay link[/url]
Posted : 20/01/2014 6:34 pm
[url= http://www.highmountainsports.com/shimano-deore-lx-m569-42t-104mm-chainweel.html ]$40 ish from Yankland apparently... [/url] (plus a fair chunk of postage?), somewhere in the UK might still have one as a spare, but I doubt shimano are still producing them, could someone else (BETD, Middleburn?) do a replacement 104/64 spider so you could use standard rings?
Unless "keeping it retro" is a big deal I'd go looking for something like wwaswas's suggestion...
Or I suppose you could lop off the 42t arms, idy it with a file and just run it as a 34/22 double?
Posted : 20/01/2014 6:35 pm
