chainset swap
[Closed] chainset swap
[#5084263]
Can I swap my 42 32 24 chain set which runs on a ten speed for a 48 38 24
Posted : 20/04/2013 1:59 pm
depends if the rear mech will cope with the extra chain length required as you now have 8 more teeth in your "longest"* gear
* BIG front BIG rear
I suspect the range between big big and little little may be a struggle for any mech and you will certainly need a long cage
what rear mech and what will it cope with ?
Posted : 20/04/2013 2:04 pm
Shimano deore xt m780 rear
Posted : 20/04/2013 2:15 pm
still need to know which one and length- three versions listed here and all XT and all say only 18 T difference at front though they cope with different size teeth difference overall
http://www.shimano.com.au/publish/content/global_cycle/en/sg/index/products/mountain/Deore_XT_M780.html#
IMHO you could probably get it to be acceptable but not ideal at changes - ie some issues at big big and little little and "sacrifice" which ones you dont want- I assume little little but you may get issues such as chain drop and/or mech to hit stuff on drive train if not careful
Posted : 21/04/2013 4:12 pm
