Chainrings Hollowte...
[Closed] Chainrings Hollowtech 2
[#290856]
Hi all.
I am in need of some new chainrings. What alternatives fit the Shimano system as due to no work at the mo, the genuine ones are to pricy.
Cheers Steve.
Posted : 09/02/2009 9:21 pm
 jonk
Deore rings are pretty reasonable. Even consider a whole Deore chainset just for the rings.
Posted : 09/02/2009 9:28 pm
I take it they are made of steel? suppose they will last longer than the alloy ones.
Posted : 09/02/2009 9:32 pm
je james (i now i know) have deore rings for under £8 each
Posted : 09/02/2009 9:53 pm
Cheers Ralph, I will try them.
Posted : 09/02/2009 9:58 pm
i like middleburn, but the deore are undeniably good value.
why not get two!
Posted : 09/02/2009 10:04 pm
i did - $14.08 delivered for 2 32t
Posted : 09/02/2009 10:06 pm
 jonk
Deore middle and inners are steel & outer is alu. Full chainset including BB is 45 notes from merlin.
Posted : 09/02/2009 10:12 pm
or £30 [url= http://www.petracycles.co.uk/product_info.php?language=en&currency=GBP&products_id=9808&source=googlepbs ]here [/url]
sell the crank arms to a single speeder - rings for £20
Posted : 09/02/2009 10:14 pm
Just note, the inner chainring for non-HTII chainsets might not fit around a HTII bottom bracket. The tabs where the bolt holes are - these are longer on non-HTII and won't fit over the bearing cup without some serious filing. And being heat treated they're as tough as a T-2000 on steroids 😉
Posted : 09/02/2009 10:21 pm
As long as this doesn't happen
[img] ?v=0[/img]
That's a lot better than @ £60 for the XT ones.
Posted : 09/02/2009 10:22 pm
mtbtomo
If its only the inner part of the mounting, then a grinder will probibly fit?
paul4stones
How much stick did you give that poor ring?
Posted : 09/02/2009 10:26 pm
It took me about 15min to grind down a deor inner ring with a Dremel, just use the old ring as a guide
Posted : 09/02/2009 10:28 pm
It's an XT one actually - alloy rather than steel. It's been on a SS but only for about a year . . .
Posted : 09/02/2009 10:45 pm
