chainrings help
[Closed] chainrings help
[#4185538]
Hi, I've bent my chain ring and it's clicking interminably! Does it matter which one I order as long as it has the same number of teeth? I'm using sram mech and shifters so will a shimano chain ring work OK?
Posted : 22/07/2012 8:23 pm
You buy a chain ring that suits your brand of chainset.
Posted : 22/07/2012 8:27 pm
The big ring (Which I've removed a while back) odds a truvativ if that helps?
So do I have to get another truvativ?
Posted : 22/07/2012 9:06 pm
Doubtful a shimano chain ring will work, which chainring is it ? What crankset do you have ?
Posted : 22/07/2012 9:11 pm
It's the middle ring that needs replacing. Currently running double and bash, but an switching back to 3x10 when I fit new middle ring. Cranks are truvativ x9.
Posted : 22/07/2012 9:20 pm
You can buy a different brand of rings but they need to be Truvativ/Sram compatible.
Posted : 22/07/2012 9:43 pm
Right, OK so am I right in thinking that if the truvativ ones are marked 104 BCD and are 4 bolt, and a superstarone is marked 104 etc, then they're compatible or am I looking at the wrong details?
Why can't it all just be easy!?
Posted : 22/07/2012 9:55 pm
