Chainring bolts gre...
[Closed] Chainring bolts grease or Locktite?
[#6913579]
Just about to assemble a single ring crankset do I grease or locktite or dry?
Posted : 06/03/2015 6:56 pm
Always use some form of lubricant/anti seize. Never dry, as you cannot achieve the correct torque when dry. Never needed loctite on any of my bike bolts tbh. A wee check of all bolts with the appropriate hex and torx keys every wee while takes a minute or 2.
Posted : 06/03/2015 6:58 pm
I use 222 loctite.
 kilo
I've never used anything on a chainring bolt, never had one come loose or refuse to come undone
3 responses, 3 different answers.
Posted : 06/03/2015 6:59 pm
🙂 will give it 10 minutes then go for the most chosen option 🙂
Posted : 06/03/2015 7:01 pm
 kilo
postierich - Member
of course if no one posts another answer, given that we've had lubricate, lock and do sfa, youre a bit screwed 🙂
Posted : 06/03/2015 7:03 pm
cytech level 3 qualified forum members to this post please!
Posted : 06/03/2015 7:05 pm
just grease, why locktite? never seen any from factory being locktite
Loctite
There should always be enough lub flying around in that area, to make seize worries unwarranted
Posted : 06/03/2015 7:06 pm
Pilot drill em & Lock wire
Posted : 06/03/2015 7:08 pm
I have had a few bolts come loose on other chain sets but they have always had stock chainrings fitted and never gone aftermarket except for my SS but cannot remember what I did with them!
Tac-Weld just to be sure
Copper grease
Posted : 06/03/2015 7:09 pm
Anti-seize for rotor bolts, bottom brackets, seat posts (fine amount - aluminium post to steel frame) and pedals. Grease pretty much everything else.
Posted : 06/03/2015 7:12 pm
Loctite
So, how does this 'flying lub' penetrate the threads then ?
Posted : 06/03/2015 7:15 pm
@ Nobeerinthefridge
How does anything else ??
Posted : 06/03/2015 7:31 pm
went for the dry run and looks like I need shorter bolts grrrr .
Will go with the copper grease suggestion when I get the right bolts!
Posted : 06/03/2015 7:37 pm
Samunkim - by applying it to the threads. Simple really.
Posted : 06/03/2015 7:41 pm
Rich, try turning the chainring round, so that the bolts sit on the flush side and not in the recess.
 JoeG
Grease on 2, loctite on 2. 😉
If a 5 bolt, leave the 5th one dry...
Posted : 06/03/2015 8:47 pm
Posted : 06/03/2015 8:50 pm
I just use a spot of philadelphia on mine. Or if I'm out of that then helmans mayonnaise normally does the trick.
Posted : 06/03/2015 8:53 pm
That's about all that hellmans is fit for.
Posted : 06/03/2015 8:57 pm
I manfat mine on.
Posted : 06/03/2015 8:59 pm
Whatever floats yer boat Stu!
Posted : 06/03/2015 9:01 pm
Shimano anti seize and set each bolt with torque wrench so the bolt tension across the chainring is balanced
Posted : 06/03/2015 9:18 pm
