Chainring Bolt Tool...
[Closed] Chainring Bolt Tool - I know, I'm sorry 🙁
[#9492507]
Looks like the Parktools version is made of Vegan Cocunut-based cheese substitute
The Ice Toolz one looks OK
Are they called anything else? Could I get one that isn't specifically for bikes?
WHICH ONE SHOULD I BUY? 😥
The lad's 1 x conversion is turning into a bit of a Yak Shaving extravaganza 👿
Posted : 13/08/2017 8:49 pm
Do you have an old, flat-bladed screwdriver and an angle grinder?
Posted : 13/08/2017 8:50 pm
[quoteDo you have an old, flat-bladed screwdriver and an angle grinder?
Posted : 13/08/2017 8:52 pm
Genuine Shimano ones last longest at work but now you can get bolts with a 6mm hex one side and 5mm for the other
Posted : 13/08/2017 9:17 pm
The screwdriver job is all very well but what about the bolt that's directly under the crank?
Posted : 13/08/2017 9:44 pm
There isn't one?
Chainrings that have threaded inserts are way better and should have been invented years ago.
Posted : 13/08/2017 9:47 pm
There is on all my 5 arm cranks 🙂
Posted : 13/08/2017 9:48 pm
 cp
The problem with the screwdriver ones is that you sometimes can't get enough purchase/force to hold the back of the Bolt in place.
That Evans one looks good.
Posted : 14/08/2017 8:45 am
These ones, with a hex head on both sides.
[img] ?itok=Kr_empTs[/img]
Posted : 14/08/2017 8:54 am
The Evans one is very good I've found
Posted : 14/08/2017 9:52 am
 Bez
The Shimano one has a bolt spanner on the other end which fits self extracting crank bolt caps, so that's my choice?
Is there a good source for the 5/6 double-hex bolts? I've only ever come across them on SRAM cranks and that's an expensive way to buy 😉
Edit: ok, found the Truvativ black ones. Don't suppose there are any fancy coloured ones around?
Posted : 14/08/2017 10:06 am
Evans one sold under various brands - I have the Park and Shimano ones too, but close proximity to chainrings more likely results in skinned-knuckles as they're more difficult to get purchase.
Posted : 14/08/2017 10:12 am
Finding out about the 5mm/6mm bolts on my Sram chainset (the LBS had to explain to me) was a revelation.
Anyone got a link to an aftermarket set?
