chainline
[Closed] chainline
[#6333029]
Upgrading a bike with 68mm UN52 BB to HT2 BB70 setup. It previously had a chainline of about 48mm, the BB70 with 2 spacers drive side and 1 non drive, gives a chainline of about 52/53mm. But the crank arms are about evenly spaced to the frame.
Can I remove 1 spacer from the drive side without needing to add one to the non drive? Or must there be 3 spacers in total?
Posted : 11/07/2014 12:25 pm
you need to switch it over, not just remove it.
Posted : 11/07/2014 12:32 pm
Will it be noticeable having the pedals offset from centre? I can't see any alternative, other than increasing the chainline, but I'm concerned that'll have a knock effect on the rest of the drive train?
Posted : 11/07/2014 12:44 pm
