Chain tension.
[Closed] Chain tension.
[#3824860]
How much movement should there be on a normal 3x9 mtb setup? Only reason I ask is because I have noticed a bit of chain slap on the bottom of the drive side chain stays where it meets the BB on my Cotic Soul. When I think about it the chain does make a bit of a racket when out on the trails and it easily touches the chain stays when I move it by hand. Do I need to take a link out or is it fine? The chain had never jumped off the rings and doesn't slip.
Trevor.
Posted : 31/03/2012 10:21 am
IIRC from the fitting instructions of Shimano mechs it used to be chain round big ring and large sprocket plus two links.
Not sure if this is still current.
Posted : 31/03/2012 11:15 am
this is what I go on: http://sheldonbrown.com/derailer-adjustment.html#chain
Posted : 31/03/2012 11:24 am
