Chain stretch quest...
[Closed] Chain stretch question
[#5923469]
I have a very stretched chain (daylight between it and the rings) and no chain checker.
Will my SRAM powerlink have stretched just as much or is this made of stronger stuff?
Posted : 05/02/2014 8:59 pm
Chains (side plates) don't stretch.
Pins and rollers wear.
Posted : 05/02/2014 9:05 pm
Makes sense. That's a no then, so that's good, I can reuse it.
Thanks.
Posted : 05/02/2014 9:09 pm
If it's a 10spd you can't
Posted : 05/02/2014 9:21 pm
Get a KMC one then you will be able to.
Posted : 05/02/2014 9:37 pm
 JoeG
The quicklink pins would probably wear just a much as the ones on the chain...
New chain, new quicklink.
Posted : 05/02/2014 10:49 pm
Your not supposed to reuse them but whats the worst that will happening?
it might snap under pressure, rip your rear Mech off, go into your spokes, damage your wheel and rear chain stays.
If your chain is that stretched you have had your moneys worth.
How much are they? £3?
Posted : 05/02/2014 11:04 pm
your power link will be just as worn as the rest of your chain, bin it. Anyway, SRAM chains come with new links.
Contrary to what some folk will tell you, SRAM power links can be reused many many times. mine get split nearly every week to clean the chain, and they click back together like they were new.
Posted : 05/02/2014 11:15 pm
What Rorschach said above: They don't stretch, they wear.
Posted : 05/02/2014 11:18 pm
Reusing powerlinks all the time too, no problem.. But yah.. New chain, new links.
Posted : 06/02/2014 1:46 am
yep SRAM ones can be popped out the splitting pliers help
Posted : 06/02/2014 2:09 am
 hora
Wow I bin my chain when it starts making a cracking noise/slipping. Powerlinks are used FOREVER.
I bumped into a lad whose rear mech went into his rear wheel on a climb on his newish bike. I wonder how many of us hard-shift chains/mechs?
I'd rather hop off- shift/spin into gear first.
Posted : 06/02/2014 7:31 am
