Chain rings and int...
[Closed] Chain rings and interchangeability
[#7100087]
Hi,
I have a truativ chainset and need a new middle ring.
Are all 104 BCD rings interchangeable?
Can I put Shimnano on?
I did do so on a Race face crank, but it needed a bit of filing down.
Also those nice Hope ones look good, but can you bung it in a triple?
Studpid questions maybe, but more fun and fatser than Google!
Cheers in advance.
Posted : 31/05/2015 11:39 am
Narrow wide doesn't work on a triple.
Most 104bcd's should work
Posted : 31/05/2015 11:40 am
I've found that a Truvativ 104 BCD middle ring will fit Shimano cranks, and Renthal and Middleburn 104 BCD rings will fit both SRAM and Shimano cranks.
So yes, in short 😆
edit- if by 'triple' you mean just the bare cranks and will be using them for a 1x set up then, that's yes as well- a 104 BCD ring NW will work on a crank that can take three rings in the middle ring position, you don't need a specific 'single' (like Zee) crank to use a NW ring (or a single ring like Renthal).
Posted : 31/05/2015 11:42 am
oooh Middleburn thats a blast from er the 1990's they were good
Posted : 31/05/2015 11:43 am
I live in the 90s 😆
Posted : 31/05/2015 11:47 am
its a shame Hope do not do a ramped ring, life would be good after that!
I am plumping for a 36 t ring, any thoughts on those? Make to be decided, though Shimano, despite being the Mondeo of bits, seems toughest.
Posted : 31/05/2015 1:24 pm
