If it was OK on a 34 front 10 speed 36 rear is it still ok with an 11 speed 42 rear?
It now sounds like when you forgot to change from big ring to middle .
I'm going to fit a 32 front will that make it any worse?
Posted : 03/06/2018 6:18 pm
I presume your crank is a double. I don't see any reason why a smaller chairing would help. You could try some chairing spacers to move it in a bit. I used some 3.5mm ones, only issue then is buying longer chairing bolts which were annoyingly expensive. But it did the job and certainly cheaper than new cranks!
Posted : 03/06/2018 7:52 pm
Single ring and as I say it all sounded fine before I went big.
Posted : 03/06/2018 8:30 pm
