When fitting a new chain am I right in thinking, large ring front and back without going through the rear mech and then take out 2 links. Fitting a new chain and can't remember?!
Thanks
Posted : 16/07/2011 12:47 am
Big big through the rear mech, then add two links.
Then check small small to make sure it has tension.
Posted : 16/07/2011 1:03 am
Thread it all thru properly, small cog rear and small ring front, chain should just (by mm) be not catching on the jockey wheel on the rear mech.
Posted : 16/07/2011 1:15 am
Am I right in suggesting that if on a full suss frame let the air out the shock and compress it first?
Posted : 16/07/2011 10:04 am
