Despite clutch and thick/thin, I still drop the chain every now and then..I suppose a hard tail is at risk of that...
Looking at chain keeper things..most are about £25, Paul's is £50.
IF is significantly better, well made, as worth it, I'll get that..
Views please!!
DrP
its not significantly better in the sense it keeps your chain on - even the superstar one i had did this- its just significantly nicer looking than that and I got it second hand for abut £20. Is it worth the extra because it's a Pauls - might be on a Dr salary 😉 - but it is well made but they all are. Not sure of weight either as the plastic superstar might actually be lighter - and i never dropped the chain on that
It certainly works well and I have not dropped my chain using it but the price is the Paul thing rather than a never drop the chain thing IME
Specialized one for £25 works fine.
Superstar one is fine. Not pretty, but fine.
The 'not pretty' concerns me.. 😉
DrP
If you're going to lose your chain with a clutch on, chances are you'll lose it off the top of the ring. Never quite understood the point of those under the swingarm ones. Add friction, don't work so well.
Depends on your mounting options, but the One Up is pretty good.
I had the light weight One Up one, it had a bit of flex in it, and it kept getting clogged with mud and sticking. After a month it just snapped in 2 in a field.
Just fitted the Rideworks one, feels like a quality product and it doesn't flex. I'll be testing it tomorrow.
[quote=DrP ]The 'not pretty' concerns me..
DrP
in that case it is definitely very pretty and aesthetically enjoyable.
