Chain fitting dilem...
[Closed] Chain fitting dilemma...
[#8353442]
Ok, so I'm installing a new bigger cassette (28 to 32T) and long arm derailleur and I've just offered up a nearly new chain, largest sprocket to largest chainring and I know I need two extra links for a "fit". However, with a powelink, I end up with a one link overlap and with an extra link (meaning new chain) I'd end up with a three link overlap, hence my dilemma!
Can I use the nearly new chain with a one link overlap, or should I fit a new chain with a three link overlap?
Posted : 19/02/2017 2:13 pm
Full sus or hard tail? Hard tail I'd go with slightly tight. full sus you sometimes get a tighter chain at some points in the travel.
Build it up with the current chain and see how the mech looks in big / big?
Posted : 19/02/2017 2:18 pm
as it is an old chain would go with if it will shift into and out of big big then it will do or add some extra bits of old chain
Posted : 19/02/2017 2:35 pm
Hard tail, CX to be exact. I'm probably being a bit of a skinflint! But loathe to install a new chain, when the old one is so new!
Posted : 19/02/2017 2:39 pm
Not too difficult to avoid riding big big?
Posted : 19/02/2017 2:59 pm
Try it, you should be ok
Posted : 19/02/2017 3:00 pm
Many thanks for the advice!
Posted : 19/02/2017 3:02 pm
