chain clicking on e...
[Closed] chain clicking on each revolution - why?
[#506507]
I know its probably a slight alignment issue of the mech and hanger but wondered if there was owt i had missed.
Yesterday i really bent the inner plate of the cage on my X9 mech, when i got home i took it off and flattened it in a vice. To the naked eye its looks flat. The hanger is 99% straight.
Gears all change fine but on the bottom cog the jockey wheel skips on each revolution of the wheel.
Is the mech so sensitive that a hanger that is about 1mm out (max) and a nearly straight mech plate would cause this to happen? Its fine in all other sprockets on the cassette, just an issue on the bottom one
Posted : 27/04/2009 6:59 pm
Stiff link!
Posted : 27/04/2009 7:02 pm
bottom being 11T or 32T?
if former, is it possible the top jockey is too close to the sprocket? Use the B-tension screw to bring it away a bit.
EDIT FOLLOWING POSTIE's POST: Im assuming when you say wheel revolution you mean it, not chain revolution?
Posted : 27/04/2009 7:03 pm
wheel rev - yes
so are you both discounting the slight anomalies in the hanger and inner cage plate?
Posted : 27/04/2009 7:04 pm
or do you mean chainring revolution ? - in which case, maybe bent chainring tooth and bigger chain angle to the "end" sprocket ?
Posted : 27/04/2009 7:06 pm
r_r - if it happens only once in a revolution OF THE WHEEL then it probably wont be a hanger issue - otherwise it would skip all the time.
A jockey wheel has 10 teeth, and (im assuming here) that your "bottom" sprocket has 11 teeth, so if it's definitely a wheel revolution (we're counting on you with this, because there's lots more possibilities if it's not a wheel rev 🙂 then my money would be on jockey wheel/cassette issue.
Posted : 27/04/2009 7:09 pm
could it be the alignment of the bottom jockey wheel as this has no float and is furthest from and bends so worst affected?
Posted : 27/04/2009 7:33 pm
if the cage is still sufficiently bent to bugger up the top jockey wheel alignment then yes.
Posted : 27/04/2009 7:36 pm
Given up - i reckon there are too many alignment issues. New mech and hanger will be here by wednesday 🙂
Posted : 27/04/2009 8:29 pm
I managed to twist a link on a sram chain the other day, so now I have two power links in it!
Posted : 27/04/2009 8:51 pm
