Chain cleaning gizm...
[Closed] Chain cleaning gizmos: what's good?
[#6203034]
My Park Tools one left me distinctly unimpressed due to it falling apart. There seems to be a few others around but what's really up to the job?
Thanks. 🙂
Posted : 19/05/2014 10:20 pm
I've tried 2 cheap ones (can't even remember what they were called / where from) and they were both complete crap. I guess the expensive ones are too.
Now I use cheap chains, wipe worst of the crap off them, and just have to cope with the sound of them grinding down my (cheap) cassettes
Posted : 19/05/2014 10:29 pm
Have used barberi and park. They're both pretty effective but the barberi would benefit from being made from a plastic that wasn't eaten by degreaser. The park is very brittle - particularly around the clamps that hold it together. Someone needs to make an all metal one.
Posted : 19/05/2014 10:33 pm
£2 lidl or aldi ones work fine, bought 2 and still on first one although it's hardly robust. I use rock n roll so most of the time when i use it it's just with water from the hose rather than degreaser
Posted : 19/05/2014 10:36 pm
I gave up on them as they're a bit rubbish. Tried this instead and it's really good [url= http://www.wiggle.co.uk/fenwicks-foaming-chain-cleaner-200ml/?lang=en&curr=GBP&dest=1&utm_source=google&utm_medium=cpc&utm_campaign=Dynamic+Search+Ads+Cycle&referid=googwig&gclid=CIKE4uL4uL4CFbShtAodPxkA-Q ]Fenwicks[/url]
Posted : 19/05/2014 10:37 pm
I went for a muc off pink coloured gizmo,decided to go for this over a park because it has a smaller reservoir so it uses less fairy liquid.not that I'm a tight wad,we'll maybe a tad tight.it works really well so far,I've had it about 4 months or so still works perfect.
Posted : 19/05/2014 10:38 pm
The best gizmo is a quick link, to take the chain off for a proper clean. All the other contraptions I've tried are only ever good for a quick, but not that good, clean when time is short.
Thanks for the replies. Good idea but poorly executed!
It started to fall apart pretty quickly, brushes fell out and one has been lost. It's not easy to use and has to go.
Posted : 19/05/2014 10:39 pm
 Bazz
Power link, jam jar and white spirit!
Posted : 19/05/2014 10:43 pm
Variation on bazz
Muc-off squirted onto wet dust pan brush hold with bristles well into the cassette turn cranks forward and drag chain and cassette across brush then rinse . This gets surface crud off.
Split chain at quick link put in plastic soup pot with your choice of degrease and shake vigorously. Remove wipe and leave to dry.
Posted : 19/05/2014 10:49 pm
Chinse food container / power link / white spirit. Cassette can go in too.
Posted : 19/05/2014 10:52 pm
Fenwick chain cleaner and sponge is all you need
Similar to others. Powerlink, oasis bottle swarfega jizer.
But the weldtite chain cleaners are probably the best of a bad bunch but don't seem to do much more than an old toothbrush.
Lidl one, £4 with cleaning liquid and a bottle of oil! Oil is doubtlessly terrible quality but does fine for the commuting SS and squeaky hinges for that matter, and the cleaner still works fine.
Posted : 19/05/2014 11:00 pm
spray the hell out of it with gt50 while turning the arms round. then dry and new oil.
Posted : 19/05/2014 11:02 pm
Bike upside down. Spray cassette with muc off, turn the cranks pressing a scrubbing brush to the chain, do the same for the cassette, jockey wheels, chainrings. A couple of minutes - done.
Posted : 19/05/2014 11:10 pm
