Ceramic brake pads?
[Closed] Ceramic brake pads?
[#837668]
No, not the braking compound the pad backing, wouldn't this insulate the pistons and brake fluid brilliantly from heat?
Posted : 03/09/2009 10:24 pm
And cost thousands!
Posted : 03/09/2009 10:31 pm
 devs
Don't you want heat to go that way? It dissipates it through the caliper and into the frame. It would be a cool night ride effect though to have rotors that glowed red in the dark!
Posted : 03/09/2009 10:49 pm
Thats the way for the heat to go if you want to boil your brake fluid.
Posted : 04/09/2009 12:24 pm
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MCYCLE&pcode=BENMRR122
£24ish for ceramic backed motorcycle pads
Posted : 04/09/2009 12:28 pm
 devs
I don't buy that at all. You'll boil your brake fluid if the heat transfer isn't good enough although it is a caliper design problem and nothing to do with the pads.
Posted : 04/09/2009 1:30 pm
