centrelock rotor in...
[Closed] centrelock rotor installation
[#360103]
Do you use the same lockring to install centrelock rotors as used when changing the rear cassette...or is it yet another tool required?
Posted : 04/03/2009 11:20 am
Same tool.
Posted : 04/03/2009 11:24 am
Hammer and screwdriver 😮
Posted : 04/03/2009 11:49 am
Ok, tried that. No problem with the front wheel, rear wheel the lockring doesnt reach the rotor due the axle being in the way...how do i get around that?
Posted : 04/03/2009 11:57 am
Some of the tools have longer recess than the others so they can go over the rear axle - this happened with me - one of my tools would do it the other would not
Posted : 04/03/2009 12:06 pm
Need a special tool if it is shimano
Posted : 04/03/2009 12:11 pm
Mundie... do you know which tool it is please mate? Would it be the TL-LR15?
Posted : 04/03/2009 12:55 pm
Sorry squire had to leave my wheel with CRC to do it when my standard one did not fit
Posted : 04/03/2009 1:25 pm
It's a standard cassette removal tool for Shimano cassettes - Park call it the FR-5. There are however different variations on a theme, some are slightly longer or have a wider hole in the middle etc to allow them to fit over axles. Same spline size etc, just a different body to the tool and it's really annoying when one doesn't work!
