Centre lock to 6 bo...
[Closed] Centre lock to 6 bolt - help!!
[#297935]
Hi,
Can anyone tell me if this will fit my splined Hope XC hub?
http://www.ukbikestore.co.uk/Product/151/HBDTCLA/ukbs/dt-swiss-centre-lock-to-6-bolt-adapter.html
Itching to fit my new brakes!!
Posted : 12/02/2009 9:14 am
Do you have centrelock hubs and 6-bolt rotors? If so, then yes this'll do the job (I use them myself 🙂 ) But if it's the other way around, then nope, they won't! I think you'd need to buy some new rotors?
Posted : 12/02/2009 9:16 am
I didnt know Hope ver made a splined hub?
Posted : 12/02/2009 9:17 am
except for the really old ones.
WOuld this fit?
http://www.chainreactioncycles.com/Models.aspx?ModelID=1163
youd then need a 5 bolt rotor for it I guess.
Posted : 12/02/2009 9:19 am
 jae
hey,got a few 5 bolt hope rotors to fit if you require....
rosie.ragdoll@hotmail.com
Posted : 12/02/2009 9:24 am
What Stoner says above is correct but you also need a screw on lock ring to hold the spider in place. Just make sure you get the right spider because I think they may be a couple of different spline patterns, a call to Hope should confirm this. I used to have the same system on my old Hope Bulbs.
Posted : 12/02/2009 9:33 am
Sorry guys, should have explained myself better - yes it's an old splined Hope hub. Need to fit a 6 bolt rotor.
Psycle - are you on Hope hubs? All the adaptors I have seen mention Shimano centre locks, not sure if they are the same.
Posted : 12/02/2009 9:35 am
shimano centrelock is very different to hope splines.
best to get in touch with hope I reckon (or time for a new hub!)
Posted : 12/02/2009 9:37 am
Stoner/steelfan - yep thats the spider I have now, would like to fit my shiny new Hayes rotor if I can!
Posted : 12/02/2009 9:38 am
Thanks Stoner will be gutted if I need a hub, just had a new wheel built around this one.
Posted : 12/02/2009 9:39 am
you could ask hope whether they make a splined-to-6bolt spider? But I cant find one retail, so it would prob be a special order and probably cost some.
The alternative is to buy a new XC hub which will have IS 6 bolt fitting for about £35, and rebuild your wheel onto it. or a ProII for £50ish.
Posted : 12/02/2009 9:42 am
You will need new rotors to fit your spider but Hope are pretty good they even offered to make me some avid style rotors to fit my old 5 bolt spiders once.
Just give them a call and im sure they would be able to help.
Posted : 12/02/2009 9:45 am
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=2491 ]Hayes 5 bolt rotor for hope splined/spider hubs.[/url]
This is what you need
Posted : 12/02/2009 9:57 am
I have two sets of centre lock to 6 bolt adaptor that I'm not using and can sell.
They are [url= http://www.wiggle.co.uk/p/Cycle/7/A2Z_Shimano_Center_Lock_Kit/5360033047/ ]A2Z adaptor.[/url]
and
[url= http://www.on-one-shop.co.uk/cgi-bin/sh000001.pl?REFPAGE=http%3a%2f%2fwww.on-one-shop.co.uk%2facatalog%2fOnline_Catalogue_Qr_Levers_291.html&WD=centrelock&PN=Online_Catalogue_Qr_Levers_291.html%23aWSOOCLDA#aWSOOCLDA ]On One ones[/url]
1 pair £20 posted
burdett2002 AT hotmail DOT com
Posted : 12/02/2009 10:32 am
Posted : 12/02/2009 10:49 am
Oh! I know... I know... Me...Me... Put's up hand.
Clears throat. Hmmm!! OK...
Hope made the "original centre-lock" on the Ti-Hubs. Unfortunately the spline was much bigger with less teeth, and so is incompatible with shimano. There was a couple of adapters made for 6 hole rotors, (Sachs did them at the time), but there is probably no way you'll get an adapter from Hope spline to Int Stnd 6 bolt fitting nowadays. What you'll have to do is take a 5 bolt rotor in the correct size and the alminium spyder you've already got, fiddle about with washers and spacing for 10 mins, as these old hubs had a diffrent horizontal spacing to newer Int stnd ones, and it should fit. Speak to the guys at Hope for more info.
Posted : 12/02/2009 11:04 am
Right,
Here is the spider off my hub,
As you can see it has a lot more splines than in the stoners above (more shimano-esque?)
Posted : 12/02/2009 11:54 am
Sorry to go on:
Does anyone know if there would be a compatibilty issue with this:
http://www.rushcycles.co.uk/products.php?plid=m2b7s225p417
ie. different offset etc?
Posted : 12/02/2009 2:00 pm
Hi Tops, That Spider will work perfectly with the rotor from Rush cycles. I had excactly the sames spiders on my old Hope Bulbs when running first generation Mini's.
Posted : 12/02/2009 10:41 pm
Go for it!
Provided you have the proper adapter for the rotor/fork mount, there shouldn't be any other prolems other than the >1.5mm horizontal spacing. 🙂
Posted : 12/02/2009 10:47 pm
Thanks all
Those nice people at Hope are sending me a Hayes specific splined (or 5 bolt) disc. What service! 😀
Posted : 13/02/2009 11:12 am
