CCDB Air adjustment...
[Closed] CCDB Air adjustment - no clicking or end-stop
[#9383083]
Just tried to tweak my CCDB Air shock. All fine except the low-speed compression adjuster doesn't click, and the low-speed rebound adjuster doesn't seem to have a "zero" position to reference to count the clicks from.
Is this a known issue?
Posted : 14/06/2017 11:10 pm
Lsc and lsr have more of a feel than click. Not sure what you mean by 'no zero'.
Posted : 14/06/2017 11:39 pm
recommended setting for LSR is 15 clicks, but it keeps on turning so there's no reference point to count 15 from
Posted : 14/06/2017 11:42 pm
Sounds like the lsr adjuster is broken. I bought a second hand one which came with the same issue. There is only a little resistance when it reaches fully open or closed making it pretty easy to over do it. Seems like a bit of a design flaw really. Is it new or second hand?
Posted : 15/06/2017 12:31 am
It came on a second hand frame 6 months ago.
Never bothered touching it as it seemed to be set ok. Had the shock serviced locally the other week and thought I should check settings to see if I could make better.
Other three adjusters seem ok.
Posted : 15/06/2017 8:09 am
 poah
was it a CC authorised service centre that did it?
Posted : 15/06/2017 9:22 am
Good point. Don't think they are. They were servicing my Pikes at the same time.
Posted : 15/06/2017 9:51 am
Give TF tuned a call and tell them the issue, they should be able to give you an estimate.
Posted : 15/06/2017 10:49 am
