anyone know if the following Nukeproof spring is correctly lengthed and has the diameter for a CCDB 200 x 57 :
2.25" x 550 Lbs x 126mm Free Length
TIA
You've spunked that much cash on a CCDB and you're going to skimp on a Nukeproof spring?
eh ?
CRC use them on their DH WC rigs.
Get yourself an Obtanium spring to match the Rolls Royce shock 😉
possible - if my dealer gets his finger out !
I don't think Obtanium springs are available in 2.25" stroke, but I could be wrong.
TLR, also bear in mind that the free length is often only just enough to get the spring on the damper. I had to use a vice to compress the spring just enough to get the retention collar on.
geetee - 122mm is the current free length and there's loads of clearance.
priced me your ion yet 😀
