cb eggbeater bearin...
[Closed] cb eggbeater bearing size?
[#929749]
anyone know if the end bearing for eggbeaters is a standard size?
Posted : 07/10/2009 12:28 pm
 ojom
If you need them then you WILL need a bush, lock nut and seals.
Its rarely just the bearing.. if it has gone then it will be due to axial play caused by the worn bush.
Anywaaaayyyyy, the best option is to buy a rebuild kit.
Posted : 07/10/2009 12:46 pm
