My XT cassette is stuck on my Hope Pro 2 hub, any tips for removing it?
There is a thread on here about it somewhere. I unscrew what I can then tap the cassette with a screwdriver against the direction it engages. Works a treat
that can pull the freehub off though on a Pro2.
try getting a scredriver and levering off the sprockets one by one, once you've got them off there will probabaly be some damage to the splines on the freehub which you will need to file smooth before the carrier with the remaining few sprockets will come off.
Is it the lock ring that si stuck of the cassette not able to slide off?
http://www.basquemtb.com/mountain-bike-maintenance-removing-a-stuck-cassette-hope-pro-2-chris-king-hub/
This is how I got mine off
Lock ring and smaller sprockets come off easily, it's the main body of the cassette that's stuck.
Deepo, I'll try the technique in that video later.
