Cassette removal ad...
[Closed] Cassette removal advice, please 🙂
[#6254506]
Will a Park FR-5 fit all Shimano cassettes? Next door neighbour has a cheap and cheerful hybrid and has asked me to make sure it is safe for use after a couple of years sat in the garage. Only thing that needs sorting is the cassette wobbles slightly and needs tightening up, but my cassette lock ring tool seems to be a tad to big to fit. Standard twelve splines on a 14-28 7-speed cassette. Do I need a different tool to tighten the cassette up or am I missing the obvious? Cheers.
Posted : 08/06/2014 2:41 pm
Hit it with a hammer and it will fit - its a lot harder to get out mind
Serious suggestion it is probably just a very tight fit due to low tolerances on a cheap part IMHO
They never changed the size that I am aware of and I have had the same tool from 7 speed onwards
Posted : 08/06/2014 3:00 pm
Are you sure its a cassette and not a 7sp free wheel.
And if it is a free wheel you can tighten it up anyway
Posted : 08/06/2014 3:56 pm
+1 orangeboy, if it's a freewheel (rather than a cassette) then your FR-5 won't fit. [url= http://www.parktool.com/product/freewheel-remover-fr-1-2 ]This is what you'll need to remove a freewheel[/url] and as orangeboy says, tightening a freewheel requires no tools at all.
Posted : 08/06/2014 4:01 pm
Cheers, I'll have another look tonight when I get home. How would you go about tightening it without tools, if indeed it is a freewheel?
Posted : 08/06/2014 4:03 pm
pedal it.
HIghly unlikely a freewheel would be loose enough to wobble.
I'd go with spunkyard's advice.
Posted : 08/06/2014 4:09 pm
Freewheels can wobble very easy, if they are not utterly shagged and worn out you can take up the slack with a pin spanner and some shims. I did it once on my paperround bike as i was too skint/tight to buy a new one. Worked fine for another 18 months of hard graft daily on my emelle cheetah. Those were the days.
Posted : 08/06/2014 4:42 pm
