Cartridge bearings
[Closed] Cartridge bearings
[#10860509]
The cartridge bearings in my front hub were feeling really rough, so I set out to replace them (never having done this before). I used a bearing puller to remove the old bearings. To my surprise they felt a lot smoother after removal, in fact one of them seemed as smooth as the new replacement bearings I'd bought. Is this normal, and what could account for this?
Posted : 12/10/2019 4:17 pm
Deformation of the outer race as it is distorted or squeezed in the hub. A little squeezing is ok, is a press fit after all, distortion not so good. I guess maybe the pressure mean the balls run on a slightly different line or that they are running on the same line with less pressure.
Posted : 12/10/2019 4:23 pm
What he said, they will be squeezed slightly in the hub.
Some hubs specify xxxx-C-2rs rather than xxxx-2rs which means the bearings are manufactured with slightly more clearance.
Posted : 12/10/2019 4:35 pm
