Anyone know of a straight steerer carbon fatbike fork that would fit on a mk2 stooge.
https://www.on-one.co.uk/i/q/FOOOCFAT/on-one-carbon-fatty-fork
Straight steerer and carbon fatty fork, dunno about the stooge bit.
[url] http://www.carboncycles.cc/index.php?p=1661& [/url]
They do a couple of forks, you'd have to check which length offset you need
Don't forget the On One is Rear Disc Spaced, so it needs a front wheel hub that is also RDS.
The Exotic forks above are Front Disc Spaced, which can fit FDS hubbed wheels as they come, or you can convert an RDS hubbed wheel to fit using https://www.tritoncycles.co.uk/frames-forks-c6/frame-fork-spares-c152/problem-solvers-fat-fork-disc-adaptor-p11825
I'm still pissed at PX, last summer I bought a v1 Fatty front wheel that was supposed to be RDS, when I finally got around to getting the Fatty fork fitted earlier this year I discovered it was FDS... So I can currently only use a fat rear wheel, at the front I have to use my RDS FatNotFat 29er. 👿
Actually i think what i need is a 29er carbon fork that can fit a 3inch plus tyre
Any ideas?
Oli
