Carbon frame respra...
[Closed] Carbon frame respray
[#3947021]
How much does it generally cost and does it void the warranty?
Posted : 06/05/2012 1:21 pm
can cost between £150 - 300? depending on who you go with/ if you do the prep work yourself. do NOT get it baked or blasted though!
and i dont know for sure, but i would expect that it would void a warranty, as lots of the sprayers not that its AT YOUR OWN RISK! as if you go too deep on the sanding, you can brake the fibers
Posted : 12/05/2012 7:44 pm
normally repainting any frame will void the warranty. For prep I would just mildy prep the surface to remove any old flaking paint/lacquer but just with a scotchpad or some fine wet and dry.
Posted : 12/05/2012 7:58 pm
