Carbon Frame Build ...
[Closed] Carbon Frame Build No.3
Gutted. Keep going though; your build threads should be made sticky. (No pun intended!)
Posted : 11/04/2015 8:03 am
Keep I'm, keeping on.
In genuine awe on this thread.
Amazing.
Posted : 11/04/2015 8:23 am
 nant
Looks amazing. I see creme eggs have been fuellling you for this project. Now easter is over, will need something else for energy!
Posted : 11/04/2015 8:33 am
Wow! Bows down in Wayne's World way *We are not worthy! We are not worthy!* Keep up the sterling work.
Posted : 11/04/2015 8:49 am
Top work Oliverracing!
Posted : 11/04/2015 9:10 am
You've even tried to make this one look a bit better than your others! Good effort mate!
Posted : 11/04/2015 11:03 am
Sorry for the lack of updates, but been working on a few other projects, but I have finally got it built and taken it for it's first test ride!
[img] [/img] But firstly I had to replace the crushed tube, I tried to maintain as much of the good tube as possible, but ended up removing most of the straight section of the downtube as I wasn't 100% happy with it.
[img] [/img] Adding the final layers of carbon went without any major problems.
[img] [/img] I have also added a direct mount for a front derailleur.
[img] [/img]It's done!* I've been for a quick test ride and everything performed as expected and it is suitably stiff without being overly harsh. I'm looking forward to having so time to get out and do some longer rides once I have a shorter stem. I have also booked my flight to Geneva ready to do the GR5 (or a similar alpine route) on it!
*I'm still on the hunt for a lightweight black 90mm standard clamp (25.4mm) stem as the only one I had lying around is 120mm, so if anyone has one I'd be happy to buy it off you!
Posted : 23/04/2015 4:18 pm
You know I don't think it would be vain to get some stickers cut for your builds.
Seems such a shame; would finish them off nicely.
Well done anyhow, genuinely brilliant to see.
Posted : 23/04/2015 4:33 pm
Looks the best of your 3 IMO but, please, PLEASE, fit black gear cable.
Posted : 23/04/2015 5:56 pm
I've just realised I have doubled up a couple of the build photos, but you get the idea of how it comes together!
I'm not sure, I personally think stickers would make it look a bit like the chinese frames and not actually add anything. I do intend on putting small (70mm long) name stickers as I have done with my other builds.
Green was the only stuff I had lying around and tbh I quite like it, so I wont change it any time soon!
Posted : 24/04/2015 10:41 am
Loving the look of that, I've got an 80mm stem, although it's not lightweight and it's silver, but you can have it for postage if you want?
I think you need both the hose and cable green or both black, not one of each!!
Posted : 24/04/2015 12:08 pm
Page 2 / 2
