Carbon, as suitable...
[Closed] Carbon, as suitable for mtb stuff as cream cheese.....
 nimo
[#3826275]
well, my carbon answer bars are knackered. I made the stupid mistake of riding my bike over the winter , in the wet and a bit of occasional cable rub as rubbed through the carbon . Brilliant , fantastic. I am now looking around for some handlebars made from cardboard, or maybe pastry for a replacement of a similarly suitable durability......
Oh well , at least I don't have anymore of the devils thread on my bike.
Posted : 31/03/2012 7:49 pm
Cable rub on your bars? 😕
Posted : 31/03/2012 7:52 pm
 ojom
Oh so it's not the cable rubbing that's at fault. It's the carbons fault.
I see....
Yup - sounds like poor set up to me - nothing wrong with carbon bars.
Posted : 31/03/2012 7:53 pm
TBC +1
 nimo
its a little known fact , but bikes do have cables.....
Posted : 31/03/2012 7:55 pm
Not that should rub on the bars though...
Posted : 31/03/2012 7:56 pm
Cables rubbing on handlebars is a new thing to me.
I've got a wee rub mark on one of my bars from my gravity dropper cable- because I set it up wrongly in the first place, then I neglected it afterwards. So that probably means carbon's unsuitable for bikes.
Posted : 31/03/2012 7:59 pm
I've some EA50's you could have, but I'd not advise riding with them as the aluminiums suffered from cable rub so they'd probably snap.
Posted : 31/03/2012 8:01 pm
Set your bike up properly so the cable doesn't run. I've got an alloy frame with rub marks on the linkages, also alloy...they will snap, frame and linkages.
It isn't carbon that is bad, just the op's inability to set his bike up properly. How short are your cables to rub your handlebar?
Posted : 31/03/2012 8:04 pm
Single speed + brakeless = Zero cable rub (I took the chain off to reduce any chain slap induced carbon chipping too).
Simples innit.
Posted : 31/03/2012 8:08 pm
 nimo
as I said it is occasional cable rub at full fork compression and with a bit of bar turn. no cable rub in workshop situation. one wet gritty day at affan was all it took. I notice a very defencive tone to most of the replys. lucky for you you are all so fantastic, This will never happen to you. Sleep easy
Posted : 31/03/2012 8:09 pm
NOt being funny but why are they getting binned for a bit of cable rub?...is it actually worn through the carbon? Or just the lacquer?
Posted : 31/03/2012 8:12 pm
So lets re - write this
I set my bike up really badly and now its broken but its not my fault .
I should have known that the chocolate chain rings I bought from the Cadburys mini Egg Bird were dodgy
Posted : 31/03/2012 8:15 pm
Not defensive - it's just something I've never experienced, and I was surprised cable rub had knackered your bars. Have a nice evening 🙂
Posted : 31/03/2012 8:16 pm
I had cable rub wear a flat spot on one of my alloy frames. I better bin it in case it breaks. You should all throw out your alloy frames too.
Carbon is awesome, cables can wear through anything given the right conditions.
Posted : 31/03/2012 8:18 pm
 nimo
it has worn a flat on the front of the bars, through the laquer , graphics and carbon layers under that I would guess it is probably about 1mm deep. Not knowing the wall thickness it is impossible to say how much is left. It is on the front edge of the downward curve. anyway, just sounding off having found 100 pound plus bars wrecked.
Posted : 31/03/2012 8:21 pm
Why not send a pic to Easton and ask them?
It's not in tension there, so may be OK
Posted : 31/03/2012 8:23 pm
 IanW
This thread needs pictures, having trouble imagining these abrasive cables.
Posted : 31/03/2012 8:24 pm
100 pound plus bars
f*** me that carbon fibre is heavy shit
at least with ally bars you'll save nigh on 99.5 lbs
Posted : 31/03/2012 8:38 pm
Could you check the wall thickness by taking out the bar plugs and looking? I dont know if wall thickness would be constant throughout, but might give you an idea of the minimum thickness and an idea of how far you went through.
Posted : 31/03/2012 8:46 pm
So........which story is it?
Posted : 31/03/2012 8:49 pm
I've had carbon windsurf masts for years. Sails rigged and downhauled under tension rub on the mast all the while, winter or summer with sand griding at it too and not just gently either. Only thing which ever broke one of those was a wave.
Sounds like the bar was made of black painted cardboard in the first place.
Posted : 31/03/2012 9:01 pm
it's actually the epoxy that has very poor abrasion resistance.
There is a very well known material called polyurethane which is very good at resisting erosion and this is what so called 'helitape' is made from. I would suggest everyone, especially the OP, uses it in places where cables may rub - whatever your frame material as even steel is susceptible. The problem does not lie with the material but the poor set up and preparation.
Cable rub in an aluminium bar is actually likely to be more dangerous.
 bol
It is amazing how quickly cable rub will go through carbon though. IIRC one year Specialized had to replace the stays of most carbon Epics because the Brain cable was routed wrongly and rubbed through. I saw one with a big hole in the chainstay after just a handful of rides.
I guess it is a lesson in set-up learned the hard way for the OP, but it doesn't mean carbon isn't a good material when treated right. There are still a lot of old monkeylite bars out there that have been going strong for years.
Posted : 31/03/2012 9:09 pm
"one day at Afan"- just so you know, I doubt anyone believes that for a second.
HTH.
Posted : 31/03/2012 9:21 pm
I do actually believe it could happen in a day Northwind, I will get a picture of my cable rubbed carbon cube after approx 5-6 hours riding.
Posted : 31/03/2012 10:03 pm
Well, I've been rubbing my cable since I started reading this thread and it's not worn through yet.
Posted : 31/03/2012 10:06 pm
astormatt- he says he used it like that for the winter, yet it wore through in a day. It definately [i]could[/i] happen with bad enough setup but he's contradicted himself.
Hope the images work ok.
Posted : 31/03/2012 10:07 pm
Oh nasty. But if it was mine just put something over it and get on with riding.
If this threads still going I shall dig out a pic of my old carbon giant hard tail which is almost worn through on the
Chain stay yet won't fail
Posted : 31/03/2012 10:13 pm
Looks like that cable outer is too short. I'd just recable it and ride it.
Posted : 31/03/2012 10:14 pm
Poor set up and lack of maintenance failure FAIL
Posted : 31/03/2012 10:15 pm
I agree with what you are saying NW, to be honest I missed the bit about riding it over winter as half cut, but my point being I could believe it taking a day to rub through carbon as mine did. If you do know that you have rubbing why leave it? Asking for trouble.
Posted : 31/03/2012 10:18 pm
Umm Iain it is a brand new bike so not my problem, luckily I decided to change tyres and catch it when i did cubes fault for the rubbing as whoever built it at factory made front mech outer too short.
Anyway it is currently in bike shop as warranty claim for new frame being sorted.
Posted : 31/03/2012 10:24 pm
TMP...has too be.
Posted : 31/03/2012 10:29 pm
me too - just can't see how cables would rub the bars.
Posted : 31/03/2012 10:31 pm
Mine was a shifter cable that exited at just the wrong angle and the cable rubbed on the 'riser' bend.
Posted : 31/03/2012 10:51 pm
Have a look to what happened to my mates carbon bars, this was last week in the Peaks and no cable rub whatsoever!
Posted : 31/03/2012 11:26 pm
cardo - Member
Bloody Hell! WTF! What a fail! - hope he didn't hurt himself? I also hope he wasn't too far from the car/home? 😯
Feel for him, I really do...
Posted : 31/03/2012 11:33 pm
He was lucky really and came off lightly after a quick tumble followed by the bike doing a few cartwheels... but scary all the same !!!! it's failed right next to the shifter too! 😯
Posted : 31/03/2012 11:43 pm
lets be honest though, they are Sunlines and they did recall them all last year....
Posted : 31/03/2012 11:51 pm
cardo - Member
Do you think that's coincidence?
cardo - Member
Coincidence or cause?
Looks like the oversized version? Sunline issued a total recall for those on safety grounds.
Posted : 31/03/2012 11:53 pm
