I have had my road handlebars slip a bit, I think my stem isn't a particularly good design, so I was thinking of changing it. But then I realised maybe I could simply use something to help prevent the bars turning. I know there's carbon anti-slip paste for this, but I was thinking threadlock could help slightly bond the bar to the stem which, combined with the pressure of the stem plate would do the trick.
I have only seen two kinds of anti-slip compound - one was a light oil with grit in it, which I'm told is bad, the other was tacky cream like a glue stick. I didn't think either were particularly useful at the time.
I have/use the gritty stuff, no issues to report and it does what it's supposed to. I only really use it on stem face plates and seat posts.
I used some of the carbon gripper paste from Halfords this week and it stopped my bars spinning so easily. Only cost 3 quid so I didn't expect much but it seems to have worked.
I have some gritty stuff still. It's a bit.. runny, not exactly grease, but I guess that's the point. But I also have Loctite.
I thought I'd read that you weren't meant to use the gritty stuff?
I have Finish Line Fiber Grip, it's more of a grease consistency but isn't sticky, definitely not runny.
Just do the bolts up slightly tighter.
NO DONT DO THAT!!!! Especially if they're carbon bars.
Use a troque wrench to torque them correctly. If they're carbon then I'd always use carbon assembly paste AND a torque wrench. all too easy to crush carbon bars if you just keep tightening.
I thought I’d read that you weren’t meant to use the gritty stuff?
Trek 2011, context is the steerer: https://thegoldenwrench.blogspot.com/2011/09/tech-bulletin-from-trek-regarding.html
the muc off carbon fibre paste is brill. and smells fabulous
