34.9 outer diameter on a BR IIRC
No worries cheers for the heads up about 18bikes, enjoy the new BR it looks sweet.
Will you be having a Friday night build tread like mamadirt does?
Can you remember off hand the OD of the seat tube on your current/old BR jedi?
34.9
[url= http://www.vitalmtb.com/product/guide/Frames,7/Transition/Bottlerocket,2790 ]http://www.vitalmtb.com/product/guide/Frames,7/Transition/Bottlerocket,2790[/url]
EDIT: too slow.....
Just for comparison a lot of frames have a 34.9 OD / 30.9 ID seat tube. Most Santa Cruz for example, so reaming out shouldn't be a problem unless you're giving it a hard time. 🙂
That frame looks a giggle jedi. Post some pics when its done.
Thanks slowrider and jockhaggis, much appreciated.
If my frame has a larger seat tube OD than 34.9 i'll email 18bikes otherwise i'll just go down the route of a 27.2 and shim untill i can afford a new frame.
I don't do the same type of riding as jedi but being a bit of a clumsy hefer it'd probably be a safer bet.
Well maybe not if the santa cruz bike are ok with it?
Specialized frames also have a 30.9 id and 34.9 od.
Looking good Tony. Think I can see the shock clearance issues they were on about from that pic, hopefully it'll be ok though!
i reckon it will be fine the otehr way round 🙂
