Can't install ...
[Closed] Can't install HTII bottom bracket.....grrrrrr!
[#7553472]
Trying to install new BB on a new Inbred frame, but the threads just won't catch to screw the cups in. Suspect there is too much paint over spray, or the threads on one or the other aren't quite right. And yes, I am trying to install them the correct way, I double and triple checked!
Any way to sort it without taking it to the LBS? Who had it at the weekend to install the headset..... 😳
Posted : 03/01/2016 8:19 pm
If you have a metal pick (or something else small sharp and pointy) use it to clean out the threads.
Posted : 03/01/2016 8:21 pm
I've had this before and by turning the bb cup the wrong way a few times it normally finds a start. Good luck.
Posted : 03/01/2016 8:51 pm
runa stanley knife round the threads, carefully, so aas to clear them of paint etc.... i've had to resort to that before now, and it worked out well
Posted : 03/01/2016 8:53 pm
d3chris - Member
That sounds like a really bad idea
Posted : 03/01/2016 8:55 pm
Clean the threads out and it should go in.
If stuck your lbs should have a cutting tool to Re do the threads.
Or if you have an old square tapered BB send that in from the other side and all the way through. It will clean the threads as it goes. Just don't get it stuck.
Good luck
Posted : 03/01/2016 9:01 pm
Standard engineer's practice: you hear a click when the end of each thread steps past one another. It doesn't wear the threads as you aren't attempting to thread the two together.
Posted : 03/01/2016 9:03 pm
I banged an old bb through mine before to clear threads on an onone
@honourableGeorge I don't mean hard to try to make it go in I'm talking about gently and you hear/feel the start of the thread then spin it the right way and it starts.
Posted : 03/01/2016 9:16 pm
thats how I do it too
Posted : 03/01/2016 9:27 pm
@fd3chris - Ok, makes sense now, sounded more like you were threading in a bit
Posted : 03/01/2016 9:30 pm
Dig an old BB cup out, saw halfway down the threads (in the direction that the axle would take) twice to make four slots. Clean the slots up with a file and screw the sawn cup in carefully by hand. Any concerns? Stop and go to the LBS
Posted : 04/01/2016 6:58 am
That's not going to work, one sides LH thread the other is RH threaded.
Posted : 04/01/2016 8:53 am
LOL ^
Posted : 04/01/2016 11:01 am
