Right found myself a Cannondale hardtail.
I have a few questions though. Not too up on modern MTB stuff. I spend most of my time and money over at Retrobike.
But here goes.
I have a set of M960 cranks. Can I use them on a BB30 bottom bracket?
How do I change the bearings on a BB30?
What headset bearings do I need for a Flash frame with Headshok forks?
Will a 10 speed front mech work on a 9 speed system?
I think thats all for now. If I think of any more I'll be back. Thanks in advance 🙂
Yes you can use the cranks but will need a bb30 to 24mm axle adapators, someone like problem solvers make them.
Bearings are easy enough to change, FSA make a drift for removal, couple of quid, put it in and tap with hammer and punch, then press in the new ones.
Would [url= http://www.ebay.co.uk/itm/6806-2RS-NIS-KG-Budget-Sealed-Cycle-Bearing-30x42x7mm-61806-2RS-/400334313523?_trksid=p2054897.l4275 ]these[/url] be suitable replacements for the BB30 bearings?
