Cannondale Omega Re...
[Closed] Cannondale Omega Rear hub help?
[#986039]
I've got a Cannondale Omega rear hub and the bearings are knackered.
Does anyone know what type of bearings they take ( I assume its a rebadged hub of some type ) so I can get it working again.
cheers
stu
Posted : 26/10/2009 11:06 am
 Davy
If they're cartridge type bearings, the number will be written on the rubber seal.
I get the feeling that they've called quite a few of their hubs "Omega", so there's no easy answer, other than to take it apart and check them. If by any chance the number has worn off, measure the outside diameter of the casing, the inside diameter of the hole, and the depth, and any bearing supplier should be able to find you the right ones.
Posted : 26/10/2009 11:19 am
 dale
formula made a lot of the omega hubs
if its ball bearings youre local bike shop should have them
Posted : 26/10/2009 12:20 pm
