Anyone know the axle to crown length of a 2001 era cannondale badboy fork?
Also, show me yours 🙂 So far I've got the frame and some EA70 bars and a stem and I need inspiration for the build.
I had one with a "tribal" pattern on - is that the one? Don't know the figure, but there was room for a 2.1" tyre and not much mud under the crown. I did put on a MX Comp 100mm fork but it wasnt right - felt all wrong and too heavy so I sold it
Mine was stock bar a suspension seatpost as the 1" tyres are not very comfy. Would recomend a bigger ring at the front than a standard mtb if you are gonna keep it on the road. Oh and I had really long bar ends on that bent right back almost 45 degrees to the bar (anodised pink too!!)
Thanks tim. I'm probably after a lightweight fork in the 39-41cm A to C range I guess. I am setting it up with flat bars initially but may try out drops as the geometry looks like it might suit it.
