Cannondale XLoc Full Sprint remote lock not working on front & rear press's in then stays in with no lock out.
Possible bleeding issues, what do you think ? Oh & this is on a new bike....
The suspension lock works in reverse, when the button is pushed it is unlocked, and when it is released is should be locked.
You can also try winding the silver/gold adjuster all the way in (+ sign).
Thanks otsdr makes sense lever in, suspension unlocked maybe not enough oil pressure to pop lever out for it lockout, tried adjusting it that made the cable disengage from the remote switch opps ... was a bit loose though, just looked online at the adjustment (gold barrel) mines plain black with no markings.
hopefully just a bleed should sort it out.
