Cane creek series 1...
[Closed] Cane creek series 10 bearings tapered source?
[#4925932]
Well, I have taken apart the shonky press fit bearings and regreased them.
Large bottom is 52mm AAA00041K and top is 4?mm HSS20133K - any idea how I can get replacements - the steel bearings are a little rusty and will go at some point.
Wally.
Posted : 04/03/2013 7:49 am
If its a taper headset there's half a chance Superstar sell the bottom bearing. Off the top of my head the one they sell is 52x44x7 and 45x45 degree. I've used the same bearing in 2 non Superstar tapered headsets now.
Posted : 04/03/2013 8:02 am
Be cheaper to replace the whole headset
The 10 is a horrible cheap unsealed plastic piece of crap
Mine lasted 2 short wet rides before seizing up
Replace the bearings and you will only be doing the same again in a few months, get something with better (any) seals and then replace bearings less often
Posted : 04/03/2013 9:20 am
