My shock currently has 22mm mounting kit either end using the spherical bearing 'bush' set up.
My new frame downtube mount is 25.4mm wide so I need to change one end of the shock mounting kit.
My digital vernier calipers (and physical test) show that an ordinary Fox bush doesn't fit, so I can't fit a standard heavy duty mount kit. It would appear...
Am I wrong? Is there an easy, off the shelf, solution? My LBS's are not exactly supporting my quest very well!
I don't really want to get some new ends caps machined because over a certain shock mount width the advice is go DU bush and pin.
TF Tuned couldn't help.
I wanna ride my new frame!!!
Anyone help? Thanks!
Tried Stendec? They are the UK service people
good man, thank you, just called them and it's getting sorted on Monday!
BETD made some for me, due to the eyelets being odd sizes.
