hi gang.can i use a small amount of finish line Teflon grease on the wiper seals on my pikes when servicing of does it have to be something specific that doesn,t react with fork oil.
cheers all.
I do, no idea whether I should or not and I'm still alive.
hahah.good answer.but i need the truth 😉
bump
It may not be a good answer but it's the only one I've got. I've been doing it for years and never had any problems:)
As i understand it there are no problem with Teflon grease. Its lithium grease you need to avoid near seals as it attacks them.
I use RSP Ultra slick grease on wiper seals.
TF Tuned recommend using Finish Line dry lube with Teflon to lube the wiper seals after riding. Clean outside of seals and stanchions first. Lube then cycle fork 20 times, clean excess off.
I was recomended rock'n'roll super slick, seems to have done a super job so far.
thanks mark.i knew it was one of them was bad for the seals..
nice one...
forkjuice....yes its forking expensive but god its good.
