Can you remove chai...
[Closed] Can you remove chainstay protector on a 2016 Orbea Occam?
[#7742526]
Fitting an invisiframe kit and chainstay protector needs to be removed to be fitted correctly. No obvious way to remove as far as I can see. Any ideas?
Posted : 01/04/2016 6:47 pm
Simple answer, yes you can just takes a bit of force, not sure how many times I'd like to take it off and on as needs some bending to make it shift.
However lots of grime behind it so good idea to remove and clean. Think I'll roll am inner tube over the top as well
Posted : 01/04/2016 7:33 pm
