Can you fix a shift...
[Closed] Can you fix a shifter?
[#3227771]
Bought a set of XT shifters last week the 9 speed of which, when the LBS tried to fit the cables and such... were discovered to be stuggling on the downshifts, making a distinct crunching sound before ceasing to work altogether. Am a tad miffed at the moment, especially as the shifters were described as working perfectly 🙁 🙁
Would just like to know whether there's any chance of rescuing it, especially seeing as it looks fine.
It'd help a lot 🙄
Posted : 09/10/2011 8:56 pm
Take off the cover to the internals, usually a small screw or allen key. Look to see if there is anything caught in the mechanism maybe a stray strand of cable from fraying.
I've had this before, worth ago, otherwise no, it sounds like the springs is damaged or being impeded.
Posted : 09/10/2011 9:02 pm
flush it with some spray oil.then spray light grease in.
(while sitting on a white leather sofa wearing a linen suit)
S'all you can do.
Posted : 09/10/2011 11:03 pm
Do what Brick said, stray cable strands can cause probs.
Which version of the shifter do you have? I know newer XTR-M970s are easier to get apart (and back together!) than older XTR-M952s, don't know if the same is true of XTs
Posted : 09/10/2011 11:05 pm
