Garden needs watering
Elton John's next spectacles...
That looks massive..
garden needs watering
If only I had a spare cup of water
That's because either
1. It's taller than the mountains*
or
2. It has 120mm cranks.
*and has 120m cranks
Genius whoever thought... where should the seat mast extend from? I know! The mudguard!
Where should the bottom bracket join? I know! The mudguard!
That looks like a greyhound taking a shit
Looks easy to clean at least
Am I just weird to say I'd love to have a go on it?
long, low and quite possibly slack - bang on
hmmm - despite it's ugliness, I'm quite impressed by the rear mudguard being part of the rear triangle. Although I suppose a plastic mudguard weighs nowt. I'm less impressed by the use of the rear mudguard to support the saddle when there's a mahoosive big mounting point right under it though.
I’m less impressed by the use of the rear mudguard to support the saddle when there’s a mahoosive big mounting point right under it though.
Likely makes it a damn site more comfortable to be seated on.
Thanks.
all that work and such a nasty stem!
Sooo many headset spacers that they ran out of silver and had to finish with black (or are they really green?)
I've got a book somewhere on the use of computers to evolve the design of things like cars and bikes, turns out if you give a computer the basic parameters and run it through many design cycles it 'evolves' something very similar to the modern car. The conclusion being that in many cases, what you see is not the result of conservative design choices or fashion, but actually the best solution given the existing constraints.
That just popped into my head when I looked at that picture; maybe a couple of triangles is just the best solution after all.
How does it steer?
Not very Women friendly is it.
Skirt all tucked up on the bendy top tube and it’ll be more like “you can see my pants from here”
I’ve got a book somewhere on the use of computers to evolve the design of things like cars and bikes, turns out if you give a computer the basic parameters and run it through many design cycles it ‘evolves’ something very similar to the modern car.
If you use a mac you get a T5 California.
