Can someone please ...
[Closed] Can someone please help (mixing road & mtb gearing)
[#521277]
Hi all,
I'm going to put some gears on my Cotic RoadRat and have come to a bit of a stumbling block with the front gearing. I've picked out a 9-speed cassette and rear mech (both sora) and intend to use deore mtb shifters (on Mary Bars).
-Will a front deore shifter (ie three speed) work ok with a road double chainset?
-Will a rear road mech and cassette work ok with a rear deore shifter?
All suggestions greatfully received!
Posted : 03/05/2009 5:19 pm
yes all cross compatible
Posted : 03/05/2009 5:26 pm
 tang
think the back should be fine. front is where the problems can occur. a mtb front mech(max 48t) on a road chainring wont work (not enough throw). shimano do a front mech for flatbar shifters. dont know if the deores are compatable with that.
Posted : 03/05/2009 5:28 pm
Only trouble you may have is with an MTB shifter and road front mech, they can work together, but not always very well. Rear 9 spd stuff all works fine, although getting anything bigger than a 28 in the back can be a problem, I've ran an 11-32 with Tiagra mech before though.
ditto, the front wot work, a roadie fron mech can work with MTB shifters sometimes, but obviously you loose the ability to trim the mech to let the chain through without rubbing.
Posted : 03/05/2009 5:30 pm
Thanks for all the responses, I'll try to track down the mech that tank mentioned, I guess I could always just use an old thumbie for the front 😀
Posted : 03/05/2009 5:44 pm
 tang
i also run flatbar specific shifters for road gearing. [url= http://www.sjscycles.co.uk/product.asp?pf_id=5791&src=froogle ]these[/url], got mine from ebay for £20. parker inernational were good for the front mech. [url= http://www.parker-international.co.uk/7407/Shimano-R440-9sp-Flat-Bar-Front-Mech.html ]here[/url]
Posted : 03/05/2009 6:07 pm
