Hi all,
OK, I have a RS Pike 426 coil.
I have semi-modded it; removing the poploc lever, unhooking the spring in the internal poploc assembly, and adding a o-ring or similar to the poploc dial on the top of the fork to stop it spinning, so I can have full adjustable compression adjust without a lever.
It doesn't give me the full adjust I had hoped for, but that's for another day.
Anyway, apparently my fork has both Motion Control (MoCo?) and Mission Control. What are these, and what do they do?
I ask as I've just seen Loco selling conversion kits, and not quite sure what they're for?
http://locotuning.co.uk/rockshox-spare-parts.html
Ta, Duane.
it has one or the other - not both
It has Motion control~ mission control was designed for longer travel forks 160mm and up.
This should help: [url= http://forums.mtbr.com/shocks-suspension/end-all-explanation-motion-control-damping-136225.html ]Geekery[/url]
