Can seam sealing ta...
[Closed] Can seam sealing tape be restuck?
[#638031]
The waterproofing seam sealing tape on my 5 year old paclite smock has started to come undone in places. I'm not too upset as the jacket has done really well and been worn loads but I would like to continue to use it.
Does anyone know whether re-sticking the seams is a sensible plan and if so what the best type of glue is?
Posted : 16/06/2009 2:12 pm
I ironed mine back on. It is the sort of stretchy rubbery clear stuff that had the imprint of the seams/ststching still in it when it came off so I guessed it was melted on there in the first place. (i don't think all seams are like that though), did it on a low heat veeeeerrrryyy sloooooowwwly through a teatowel and it sort of melted itself back on. It did take ages, mind.
Posted : 16/06/2009 3:03 pm
Ooh, hadn't thought of that. I'm pretty certain that they are applied with heat so ironing probably is a good plan.
Any other thoughts?
Posted : 16/06/2009 3:14 pm
I tried McNett SilNet (silicon seam sealant) once out of curiosity on an old jacket... it doesn't work.
But the same people suggest SeamGrip for reattaching seam tape:
http://www.mcnett.com/Seam-Grip-Seam-Sealer-Outdoor-Repair-P133.aspx
Posted : 16/06/2009 3:31 pm
