Am I right in thinking RL forks aren't travel adjustable, and does anybody know if they could be made travel adjustable and have better damping like in RLTs?
Thanks,
Tim
Now not he's at Madison Saracen
Right. Could the company TFTuned do what i'm asking about?
Yes it is possible to fit a Uturn coil assembly or dual position air spring system and you could also fit an RLT moco, but would be better off fitting a blackbox Ti moco and dual flow rebound assembly (as used in the RLT TI Revelations from last year.
For a performance upgrade, damping wise the cheapest option is to just fit a dual flow rebound assembly and a uturn coil assmebly, however once you've paid for parts and labour you would be not far short of a set of last years Dual position RLT ti revelations, if you can find some.
Euther way feel free to drop me a mail if you have any further queries.
dango - do you not now?
Thanks for the response Loco, will email.
Tim
An call or email to TF would have been a more direct way of finding out!
bigjim - Member
Not at eight o'clock on a Sunday night it wouldn't.
Loco, I have some 2012 Sektor rl Dual Position forks. What, if anything can be done to these forks upgrade wise? Cheers Ian.
The Blackbox dual flow rebound assembly can be fitted, reducing the amount the forks pack down on reapeated hits and generally giving more control through out the range.
Feel free to mail me for more details.
Have e-mailed you about the forks Loco.
Thanks,
Tim
LoCo - MemberYes it is possible to fit a Uturn coil assembly or dual position air spring system and you could also fit an RLT moco, but would be better off fitting a blackbox Ti moco and dual flow rebound assembly (as used in the RLT TI Revelations from last year.
I thought RL revelations had the dual flow damper already?
