Can powder coat &qu...
[Closed] Can powder coat "crack"?
 juan
[#1379272]
Or is it my frame failing.
It's a crack all over the weld between the gusset on the diagonal tube and the headset (underneath).
I'll get a shower and then a pic. but please tell me it can be the paint and I won't have to mug a bank for 500£ to get a new frame.
Posted : 03/03/2010 6:01 pm
I think it COULD crack, I'm not sure how likely it is without metal failure first, the material is fairly flexible normally so unless there's a really large build-up in that spot I'd say the substrate has failed causing the coating to crack. I'd certainly be stripping it back from around the edge of the crack to see which it was.
Posted : 03/03/2010 6:13 pm
doesn't sound good!
Posted : 03/03/2010 6:30 pm
what he said-----^
PC is fairly felxible, certainly more so than the metal underneath.
Posted : 03/03/2010 6:32 pm
I've seen powder coat cracking due to corrosion underneath. Whatever it is you want to strip that bit back to find out - as CK said.
Posted : 03/03/2010 6:34 pm
Similar thing happened to a frame of mine a while back. Particularly as it's on a weld, sounds like a frame crack to me.
Posted : 03/03/2010 6:43 pm
 juan
Pictures are uploading flickr as we speak...
EDIT
here we go...
Weird is that is fairly recent. And I have not been abusing the bike recently...
Posted : 03/03/2010 6:46 pm
Powder can crack but that looks terminal I'm afraid 🙁
Posted : 03/03/2010 6:56 pm
Looks ****ed to me.
Posted : 03/03/2010 6:57 pm
 juan
nooooooooooooooooo
Well off to get it sanded and see if my car bodywork can do something
Posted : 03/03/2010 7:00 pm
Juan
spray some gt85 in there and then wipe off.
ride around a bit and if it stays clean then its ok
if dirt accumulates around it , then thats the metal rubbing against each other and its ****ed.
Is it a commencal?
Posted : 03/03/2010 7:02 pm
Time to put the new missus out to work the streets I'm afraid!
Posted : 03/03/2010 7:05 pm
and that kid of hers up some chimneys!
Posted : 03/03/2010 7:07 pm
Suggest to be safe you don't ride the bike and get it to the LBS sharpish! I had a similar crack on my blur on the bottom bracket and the weld was failing. Good luck with it!
Posted : 03/03/2010 7:11 pm
Put some tipex fluid or nail varnish on the crack, let dry, ride bike (gingerly), see if crack reappears. If so then its a deadun.
 juan
nasher it's not the commencal it's my handjob. I'll do the tipex/nail varnish stuff and see how it goes.
Thanks all.
Nasher I e-mailed you earlier on about italy.
Posted : 03/03/2010 7:13 pm
Just scrape the powder off with a stanley knife to be sure it's ****ed.
You'll see the crack then.
Posted : 03/03/2010 7:15 pm
 juan
I'll sand it off tomorrow morning and keep you up to date.
Best
Juan
Posted : 03/03/2010 7:49 pm
 juan
well actually it's the frame underneath the powder coat 🙁
Off to the car body shop tomorrow...
Posted : 03/03/2010 8:08 pm
Bottom of the headtube, think thats the last place I would get re-welded.
Posted : 03/03/2010 8:24 pm
 juan
Well I'll probably had a bit of material too.
Still I don't get why it failed now. While I was in soton I use to go down big steps and all. Now I just ride it and most of the time with the GF so nothing hardcore/
Posted : 03/03/2010 8:31 pm
Just unlucky with fatigue I guess
Posted : 04/03/2010 9:22 pm
Another Cove eh? And someone had the cheek to mention Commencal on this thread. I thought we'd already established that Coevs have a higher attrition rate than Commencals.
Posted : 04/03/2010 9:26 pm
 juan
Collin I though it was cotic 😉 Plus I already have a commencal. I am going to the welder shop tomorrow see if he can do something about it.
Posted : 04/03/2010 9:38 pm
Tee hee 😉
And Cannondale? Must be any brand starting with the letter "C"
Posted : 04/03/2010 9:40 pm
Don't take it to a car body shop there is no welding standard in the car industry (except manufacture). The tubes on the frame will be paper thin and need to be braised you will more than likely get some mechanic try and mig it with their welder and blow bl**dy great holes in it. Ring up your local welding/engineering companies and ask if any of them would be able to braise it for you. It will never be as strong as it was but should be able to achieve a good repair. If you don't mind it looking a bit ugly you could always get them to weld the crack, flatten it back then weld a new gusset over the top of the old one which would relive the stress from the crack. If you hadn't already guessed I used to weld for a living.
Posted : 04/03/2010 9:45 pm
 juan
blur i'lll be going to a place called scai who weld planes for a living and who have fixed the lbs owner RM7 by welding a new seat tube. I'll keep every one updated
Posted : 05/03/2010 8:36 am
Reynolds suggest ER70-S filler wire.
Posted : 05/03/2010 11:12 am
 juan
Well the soldering shop I went in are not at their first weld 😉 the secretary told me they do plenty of bike (both repair and disc mount). In the work shop they have the two bike they have made (two half made of allow welded in the middle). They do boy racer alloy rims too, and are the only one that have the accreditation to work on planes. So they seems to be very serious...
Posted : 05/03/2010 9:32 pm
Be sure to post a pic when its welded up Juan.
Posted : 05/03/2010 9:43 pm
 juan
Ok I'll try to remember (it's only going to cost 20-30 bucks).
Now which colour to powder coat it (again)?
Posted : 05/03/2010 9:48 pm
Sounds like they know their stuff and having done bikes before is a good sign. Not a bad price either.
Posted : 05/03/2010 10:09 pm
